4.02 and 4.01 won't start. 4.0 does why?
T-NUZ
Post by T-NUZ »
I have assembled my kit. seems to be ok.
I downloaded the config software and versions 4.02 and 4.01 will not run.
I get a windows crash error and they exit.
But version 4.0 runs.
Any ideas?
Post by NITROPIXIE »
Have you uploaded the firmware onto the mjlj too match the software???
http://www.autosportlabs.net/MJLJ_V4_Downloads
If you need help with this then i can pm you a guide on how to do so.
Hi T-Nuz,
Actually, the software shouldn't crash regardless of the firmware of the unit.
A few questions:
What kind of error message do you get when you try to run the 4.0.2 software?
Does it still crash if you install it on a different PC?
What version of Windows are you using?
T-NUZ
Post by T-NUZ »
It was on windows XP Pro. i say Was. strangely it started the first time today.
I had turned off the pc for the night and the next morning it started right away.
Now i have to get the communications problem with the mjljr fixed. will search the
forum first.
Thanks for the reply's
dan8400
Post by dan8400 »
Hi, i'm having the same problem now.
Can't run any of these. I have downloaded 4.02 4.01 and 4.0 all downloaded but none of them work
I'm a beginer and this is my first megajolt
What am i doing wrong??
Dan
