Maybe this isn't the place for this question but I haven't found any other place to ask it. Is the MAP sensor included in the base MJLJ V4? From the picture it looks like it has the vacuum connection, but then I see a MAP conversion kit. Just wanted to make sure before I order. Thanks.
Tom,
SOT: MJLJ V4 MAP sensor
Cheapsnake
Hi Tom,
On the order page you can choose TPS or MAP option. With the MAP option selected the internal MAP sensor is included.
The separate MAP conversion kit are for those that want to convert from TPS->MAP after the fact.
So, when ordering, simply choose "MAP" option and you will have the correct configuration you need.
Cheapsnake
