How do i test with a 9v battery? I have plugged it in to where the picture says but can't connect it to my PC. Checked port settings etc
Is the green led supposed to be on? How can i circuit test the whole pcb??
Dan
You can test the voltages with a multimeter as per http://www.autosportlabs.net/MJLJ_V4_ki ... g_Voltages
When powered up the green led is supposed to lit. Are you sure the 9v battery is connected the correct way round??
