Trigger Wheel & PIckup Install A-Series
Phaeton
Post by Phaeton »
Bought a toothed pulley & mounting bracket off ebay for the A-Series engine. Got round to fitting it today but concerned the pickup is too far away from the teeth, in hindsight I should have measured the gap, but for reference the nut is a 10mm
Any thoughts anyone?
Alan...
DannyP
Post by DannyP »
Clearance needs to be around 1 mm, otherwise looks like a solid mount.
Ken555
Post by Ken555 »
I would say that's miles too far away.
I set mine with a feeler gauge at 1/64 of an inch approx 0.5mm
Can it be mounted the otherside of the bracket ?
Ken555
Post by Ken555 »
How close mine is
Phaeton
Post by Phaeton »
Thanks guys I thought that was the case, but the kit came with no instructions. There is a spacer plate but without it the pickup is too close. Maybe it isn't a spacer but an extra support & it goes the other side of the bracket & a washer will give the correct clearance. I'll try to have another go tomorrow night.
Alan...
Ken555
Post by Ken555 »
I would say its a clamp to spread the pressure of the bolt.
So it goes like the poor Paint picture attached
Ken555
Post by Ken555 »
Or if thats too far forward try this way
Ken555
Post by Ken555 »
Knew I had seen that type of setup before somewhere.
So the 2nd diagram is correct. Here's a photo of the assembly
So its sensor/bracket/plate
The sensor can be spaced backwards with a washer if needed.
Phaeton
Post by Phaeton »
Thanks Ken
Spoke to the guy who produces these & you're exactly right, the bottom picture is how he described it, you use the washers to get the gap correct.
Alan...
Post by NITROPIXIE »
The guy who makes them is SteveD on here and the mini forum. A very helpful guy and a mate of mine has one of these aswell. Vey nicely made.
