Engine Mfg: Ford
Engine Code: Pinto
Cylinders: 4
Displacement (cc): 2000
Rev Limit: 5500
TPS or MAP: TPS
Boosted or Normally Aspirated: normal
If Boosted- max Pressure (KPa):
Modifications: Raised CR, twin 40 webers, newman fast road cam
Chassis:
Notes:
This is my 5th map so far works good, no pinking.
Give it a try- hope its of some use.
Will prob edge the timing up a bit more to see what it takes..
Capri Pinto 2.0 map
Craigorypeck
Capri Pinto 2.0 map
- pinto 5.mjlj
- (801 Bytes) Downloaded 1305 times
