After following the assembly guide for the V4 board, I checked the voltage at all the required area's. All of them check out. I then move onto the main circuit section. Once I completed that, per the assembly guide I checked the voltages. I have nothing. No voltage at any spot. I am using a 9 volt battery for the test and read 9volts off the leads. Any help is appreciated.
Erik
V4 Build No power
Hey Erik
Are you sure you have connected the 9v battery the correct way round after you installed the chips.
If you take the chips out again but be careful not to break/bend the pins of the chips and retest.
If still no luck then check all the pins you can starting from the molex then across the diodes, then the tracks which supply the chips.
Also check your solder joints for any cracks and remelt the joints on any suspicious ones.
Hope this helps
Ryan
Hope this helps
Ryan
