36-1 Trigger Wheel Size
Zottlander
Post by Zottlander »
The 36-1 Trigger wheel that i have is smaller than my pulley. The teeth are just short of the edge of the pulley.
Do the teeth have to be proud of the pulley? Will i get interference from the pulley edge running along side
the teeth? (pulley is for a 1500 Spitfire) Thanks for any help! :?:
The teeth are 3/8'' wide. I have added a photo, thanks
Finally re-sized the photo correctly...
36-1 Triggerb.JPG (41.24 KiB) Viewed 5048 times
Post by NITROPIXIE »
No you wont so long as you strategically place the VR sensor so it is covered by the majority of the triggerwheels teeth. What is the thickness of the triggerwheel???
