Ok, I know this is a dumb question, but i would like to not blow up the MJLJ.
When the wiring diagram says connector pin-out, is this looking at the MJLJ itself
and the power is on the right? Or is this looking at the end of the cable?
The reason i ask this is because the cable connector has sockets that plug onto the pins of the
MJLJ itself.
Thanks for the help....
MJLJ Connector pin-out?
MJLJ PIN OUT
The picture MEGAJOLT LITE JR V4.X CONNECTOR PINOUT is looking at the connector from outside the case. Notice the screw heads at the corners. The pin at lower right is +12v; you could verify this by tracing it back to the + (9V battery) test point on the circuit board. Incidently that is connector pin 1. The upper right pin is GND (pin 9); same check. Lower left (pin
is AUX INPUT,upper left (pin 16) is COIL POWER. Bruce Roe
