Edis Heat sink?
imp_nut
Edis Heat sink?
Post by imp_nut »
Hi all,
Does the EDIS unit require mounting on a heat sink? I can't remember the Ford setup.
All replies greatfully received, and a Happy New Year to all.
Paul.
I've thought about this, sinc
I've thought about this, since the edis module has power transistors in it to drive the coils.
I have it mounted as it would've been in the ford escort I removed it from; simply mounted using the bracket. Nothing else appears to be needed.
