Sagem coil pack wiring
Hi, just wondering if anyone has a wiring diagram for the sagem/vauxhall type coilpacks which use a 4 pin plug as apposed to the 3 pin type found on Fords? Thanks
Becareful here from my experience Peugeot have 4 pin coil packs and the 12v pin in to the pack is paralled inside the pack to another pin for a capacitor grounded to earth. So in retrospect there is 2 x 12v pins, coil A pin and coil B pin.
Now some other coil packs have a ignition drivers built in (such as on an audi A3) which would have 4 pin connectors but for different purposes. In these cases you would have 12v, ground, coil A and coil B.
I personally have no experience with the coil pack you have quoted so i don't know what you have but just to keep you awares of the slight difference available. There are a couple of simple tests with an ohmeter to determine what you have unless others now different.
Ryan
Ryan
