My set-up is working great in my old Range Rover. I need new ignition leads and spark plugs. I believe i need to use resistive type spark plugs. My question is, should i use spark plugs to suit the Range Rover engine (with a 0.8mm gap) or ones to suit the Ford coil packs (different plugs, with a 1.1mm gap)?
I am also having trouble finding new ignition leads (3 of mine are no good). Decent brands like Bosch want $800+
I've found someone local who will make some Magnecor leads for $240. I thought that was expensive for leads, but i'm quickly discovering they might actually be cheap. He has also suggested low resistance leads (300ohms i think) to suit running on LPG. Any thoughts?
Thanks in advance,
Peter.
