I'm using Windows XP in a VM on my Mac with a USB-Serial adapter from Belkin. I can read the information from the MJLJ it is working most of the time. It is intermittently unable to read values, but I try again and it works. When it's hooked up to the car the RPM and Ignition Advance gauges work perfectly, so I know there is communication between them.
I can write changes sometimes. I managed to change the cranking degrees from 12 to 8, but it took a few tries before the changes would take.
If I try and make changes in the ignition map and press "Write Configuration changes" it seems to do nothing and the "Commit changes to flash" is greyed out.
I will take a look at the 232 chip and the solder joints later, but in the mean time does anybody have any other suggestions?
-Eric
