1965 MGB installation
MGBMarty
Post by MGBMarty »
some pics of my install... 1965 MGB +40 18V block reworked big valve cylinder head, Nissan 280ZX 5 speed..
completed June 2010
This is a MAP type installation.
The ignition map I used came from the 'how it was done section"
so far I haven't modified it because the car runs so well. starts from cold in a few turns, and from hot the same..
Th car pulls hard through the gears and idles dead smooth!
The trigger wheel came from triggerwheels.com and it was for a A series engine. I milled the adapter so it sits 2 thou out from the pulley and I milled the pulley down to ensure the sensor reads properly.. the next one I do will simply be a larger trigger wheel...( 6 inches) so the pulley will remain standard.
There is a lot of theory that the damper shouldn't be modified, but so far I don't notice any negative vibrations etc.
The sensor is from a 2000 Ford Taurus.
I spend about 400 Cnd dollars in the install.
Sensor install with a custom pulley bolt
sensor install -  the fan belt is a fiddle to get between the rack and the wheel.. but it can be done
sensor install
sensor install
MGBMarty
1965 MGB part 2
Post by MGBMarty »
more of the MGB install
sensor install : sorry for the fuzzy photo , but I wanted to show the general fit and the clearances
Coil.. screwed to an old Lucas distributor cut down to size  1st glance looks stock.
megajolt installed under dash with added blue LED to indicate power
MGBMarty
MGB part 3
Post by MGBMarty »
3rd part:
EDIS module installed behind glovebox
40 CC Vaccum stabilizer capsule made from two built in Vacuum cleaner ends..  PVC
The car ( In Toronto Canada)
dr.occa
Post by dr.occa »
lovely setup. i like how the edis module is in your glove box area.
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
"Poverty is not a virtue."
Funky Diver
Post by Funky Diver »
Very nice!! I always had a soft spot for MGB's (and other british cars of the era) Top banana fella :)
M44KTS
Post by M44KTS »
Very tidy install, I love the front lip on the car, finishes it off nice 8)
1991 1275 Megajolt powered Mini
