Reply to topic Page 1 of 1
knob in car
Post knob in car
really sorry if this has been covered , but has anyone ever created a situation where ,while using a mjlt v3 ,you have a rotary knob on the dash that will advance and retard ignition from its setting on the map ?
thanks
robert .
Post
Maybe for adjusting overall timing correction on the fly.
_________________
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
"Poverty is not a virtue."
View user's profile Send private message AIM Address
Post
exactly, dr .occa.
my turbo mini a series engine is all iron ,and i find it hard to detect detonation on the rd , in fact , i was at a rr shootout a while ago ,and a turbo mini melted no4 piston with me standing about 10 ft from it ,and i still didnt hear anything .
the facility to edge the timing up ,and watch the mixture and feeling of the engine ,and also my knock lite ,would be a good thing to have .
Post
Cool idea.
You could do this today using the AUX input and have the ignition correction sub-map bump the map up and down as needed.
see the 'operation guide' on how this might work.
_________________
Post
brentp wrote:
Cool idea.
Hey that's perfect. I'll have to implement this as well. Thanks for the direction brent. There ya go ivanhoew.
_________________
AUTOSPORTLABS
NonStop Tuning
www.86garage.com
Post
brentp wrote:
Cool idea.
would this be feasable on the v3 brent ? i was thinking of a varying resistance pot that would move the spark back and forward, a bit like the msd boost retard knob , but as you know ,my electronics knowledge is neglegable . Very Happy
Post
If you go to POWERED BY MJLJ GALLERY, to KOHLER 20 HP ODD FIRE TWIN 13 May 2010, you can see a picture of such a knob. Also a PHOTOBUCKET link to more pictures. It drives the AUX input. Bruce Roe
Post
Sounds like you need to train your ears Ivanhoew, lol. I have seen a rolling road where they got a set of ear duffs and had a plastic tube running to the engine block to hear predetonition. Its quite easy to make your own set of knock sensors (using MK1 ears) and given a bit of experience to hear the right sounds you dont need a lot of expensive gear, just experience.
There is no reason why you can't use a knob(potentiometer) to adjust the advance of a megajolt unit. Just make sure you set it up correctly on the Aux input screen of the megajolt software
_________________
View user's profile Send private message Send e-mail MSN Messenger
Post
how would i do this on a v3 mjlt NITROPIXIE? oh , car is in this month mini world dyno shoot out .one of the blue ones Very Happy .
regards
robert
ahh , just read the manual for v4 , i assume one uses the temperature correction example , but run the pot on the wires that would normally go to the temp sensor ,then program in a middle resistence for zero change ,then more resistance makes a change advancing ,and less resistance makes it retard ,all programmable in the aux input doofah ?
so this looks fine ,but ,not applicable to v3 ?
so ill have to upgrade ? Crying or Very sad
Post
Quote:
'''This technique works with the V3 as well, as it too supports the option switch. I think you're confusing the AUX input feature...
With regards to using the AUX input for correcting ignition advance, V3 will have similar capabilities very soon.''
oh HO ! after reading the above post from another topic ,maybe i dont need to update ..
