open MAP
seven
open MAP
Post by seven »
I have downloaded a couple of MAP's however I cannot open them. How do I open these MAP's. Is there a program I can use? :D
You can use the Megajolt Configuration software to load the Maps; you can find them in the 'downloads' section above. You can also look at them using a text editor- they will be understandable after a bit of studying :)
