I have a MJLJ V3 bought with a non running motor, I am anxious to "save" the current Map. I understand from the previous owner it has 3.2.1 firmware and I have 3.2.1 software.
I get timeouts trying to read ignition config. The PC is an old Dell laptop running XP Pro with a proper serial port. The MJLJ is powered by a PP3 (9v) battery. I have checked all 5v sources except the one under the square shiny "oscillator" as I only have the top off currently, all OK.
I tried to communicate using hyperterminal, no response, so I tried the port & lead on an old Garmin GPS & got a stream of data so it looks like the problem is with the MJLJ or the Software rather than the PC.
On the software, it is set to 4cyl., TPS, and Com1, 4800 baud. All Hyperterminal settings were also correct.
What can I check now ?. Alternatively is there another user in the West Midlands (UK) who has a working V3 PC set up that could at least check my unit for serial connectivity ?.
Hope someone can help, Thanks .... Tony
