Ignition driver board
So lately I've been down with a bad cold - actually the beginnings of pneumonia. Last night, while loaded down with antibiotics and prescription cough syrup I collaborated on a 4 channel ignition driver board with our friend Karel Jennings. A fun diversion to keep my body rested.
Read more:
http://www.autosportlabs.org/blog/?p=1536
Wiki page here:
http://autosportlabs.net/IgnitionDrivers
Please share with your friends :)
Post by NITROPIXIE »
Will these not over heat in the enclosure at some point?? What about using the back plate of the enclosure as a heat sink of some sort????
Hi Ryan,
The heat is transferred to the bottom of the PC board to an exposed PCB pad, where it can then be coupled to the enclosure.
Assembled boards
Assembled boards are in! Nifty. Now I need something to drive them on the bench :)
Funky Diver
Post by Funky Diver »
Oh sweet!!! They look rather special!
Admit it, you're drawn to the pretty LEDs ;)
Funky Diver
Of course!!!
I am a man of simple means, and if it's shiney or blinky, I'm happy :D
Anyways... are these going to be available to buy in the store Brent? Or as a self build kit? ;)
I would really LOVE to be able to do away with as much gubbins under the bonnet (hood) as possible...
Yes- we'll have them available. Next up is to work out heat coupling to our enclosures- I think we have a fairly simple solution that puts the enclosure heat-sink finning to good use :)
Funky Diver
ooooh, oooh, oooh... put one aside for me. 8) :lol:
Although you might need to offer different LED's... green is Soooooo 80's, haha. I know I'm a picky bugger, lol.
From a personal perpective I'd probably rewire the LED's to a ground switch so that they only light up on the press of a switch to earth them (if that would work) rather than them being on all the time. Just a thought :D
cng1
Post by cng1 »
I agree. Given that the LEDs are indicating sparks/ignition they really do need to be either red or blue. Green is just wrong!
www.trigger-wheels.com
DannyP
Post by DannyP »
Personally I like white LEDs!
Hey Brent, will there be enough room to install a couple(3 in my case) of these driver boards for twin-plugging possibilities on a 6 cylinder?
You guys are roughing me up on the LEDs :P :)
The boards will fit one per enclosure, so if you have room for 3 enclosures...
An alternative is to run the LS4 coil packs, which has the drivers built in. Choices, Choices :)
DannyP
Post by DannyP »
COP all the way, 12 of them are going on my 911 motor! We'll figure it out I am sure. There will be plenty of room for 2 or 3 enclosures, btw.
Funky Diver
Brent,
I've added metric sizing to the Features section, can you confirm the dimensions are correct please?
I've also found a PCB prototyping service in the UK which is VERY competitive (compared to some) working out at less than $16 per board on quantities of 4 or more, obviously the more units, the lower unit cost incrementally.
Coupla questions on the construction,
- it is a single layer board right?
- I'm guessing the heat sink is bolted to chassis?
Cheers
Rich
Hi Rich,
Thanks for contributing to the wiki1 So it's a double-sided board. The intention of the heat sink is to bolt the board down to a metal surface, like a section of aluminum bar.
The heat sink and the bottom of the board must be insulated- i've designed to work with TO-220 insulators. I recommend the rubbery silicone pads, not mica + heat sink grease, although either would work.
I've measured that a 0.25" bar sandwiched between the PCB and the bottom inside surface will make a tight interference fit after the board has been slid into the case. This part is in progress- The wiki will be updated when I have more pics to take.
