Easy installation, works like a dream, flashed the beta firmware and I'm very pleased with it. Installation pictures here:
http://www.g2.nu/chris/mini/pictures/20050130/b
A-series Mini install + beta code
www.trigger-wheels.com
Correct URL
Scott Beavis
Mini install
Any more info on this install would be most helpful.
My mini is here http://www.beavispits.co.uk/borris/mini.html
It has a front metro rad and the dizzy stops the grille sitting back properly, even with a very low profile Maestro 1300 cap. I really need to lose/move the dizzy, hence coilpack and EDIS thoughts.
It will also allow me to insert a 2nd electric fan in behind the rad. It has a habit of overboiling in traffic!
Scott
Scott
Mini Install
Chances are that being able to tweak the timing properly you'll be able to bring the temperature down a bit. Overheating is often a sign that you're running lean and/or over advanced.
Once it's all installed you'll be able to plug the dizzy hole in the block like this:
http://www.g2.nu/chris/mini/pictures/20 ... g_2976.jpg
Keith Johnson
plugging the dizzy hole on a a series
hi, what did you use to plug the hole?
Keith.
Keith.
Dizzy hole plug
It's a cut down old dizzy, with an M12 bolt through the center. Seems to work really well.
