Firing Order
beachbuggy61
Firing Order
Post by beachbuggy61 »
Hi all,
I hope this isn't a dumb question and bear in mind that I haven't got my EDIS, trigger wheel and coils yet, but how do I set the firing order on the EDIS and coil pack? Or do I not have to? Will the coil pack have noted on it which lead goes where? Is the EDIS already set with 1,4,3,2?
These questions may well be answered when the hardware arrives, but I figure it can't hurt to ask.
Many thanks, Marc.
On Stockton Beach NSW Australia.JPG (33.32 KiB) Viewed 14245 times
Post by NITROPIXIE »
Hi Marc,
The edis 4 is used on straight 4 cylinders (1342) originally and has a different firing order to a flat four. All you are required to do is swap the plug leads around. Speak to other guys with flat 4's on here with what they have done.
Hope this helps
Ryan
Sx530
Post by Sx530 »
Hi
I have got the hardware but I have not started the installation. A general question. The Ford coil pack for the EDIS 4 has has marked the ignition cable connectors with 1 to 4. What does this order mean? Is the EDIS 4 firing these outputs in order 1-2-3-4? Or does it mean the order of the cylinders for a straight 4 engine with the firing order 1-3-4-2?
BR, Rolf
toenee
Post by toenee »
I believe the numbers on the coil pack are the order in which it fires, ie. number 1 first and four last.
So with a 1,3,4,2 firing order, number 1 lead goes to number 1 on the coil pack, number 3 lead goes to number 2 on the coil pack, no.4 to 3 and no.2 to 4.
Sx530
Post by Sx530 »
Hi toenee
That makese sense. It is the same situation as with a mechanical distributor. I am excited to see how it works. But I have to wait until spring before I can swap the engine. The winter is coming soon and I have no heating in my garage.
Thanks for yor answer.
BR, Rolf
