Hello again! I posted here back in the autumn about ford EDIS bits
and bobs and using the 16F84 PIC etc.
I still plan to convert my mini to a distributor-less ignition
system. I like the look of megajolt.
Since my last email I have aquired the following on ebay:
- EDIS4 module
- Ford Sierra timing cover with 36-1 pulley and sensor
- Ford zetec coil pack
I plan to assemble this with spark plugs in a bit of MDF and spin
the wheel with a drill. Hopefully 10'BTDC "get you home" sparks
should be produced.
If that all looks ok, then I'll move onto the next stage. The PIP-
>SAW converter. Three options here...
a) MJ/MJL/MJLjr (whats the difference between em?)
b) Home made PIC circuit using eg: 16F84
c) Non-microcontroller version with eg: bargraph ic and ten
monstable periods
Option c is the simplest and easiest to build, but is not very
elegant and will probably be a pig to setup. Option b would entail
lots of teething trouble and grief.
So, option a....the megajolt thingamijjig. So, what's the deal then?
I saw some circuits etc floating around. Do I just knock that up
onto some stripboard? What about setup software and firmware?
I *really* like the thought of having a laptop on the passenger seat
and tweeking the advance curves (not while driving obviously!)
I don't need the vacuum sensor thing (my current Aldon Yellow dizzy
is mech-adv only to 7krpm, no vac-adv) so all I need is a simple
look up table of RPM vs SAW period. Anyone got a circuit and
firmware for a cut down version which does just this?
I'm on twin SU's so no need for EFI, lambdas, TPS, etc etc. Just the
36-1 wheel that is all I need (I think).
Any advice or comments would be gratefully received. I have
electronics degree background, and do VB dev for a job, so I'm ok
with software and electronics. Firmware side is a bit rusty, but
I'll pick it up I'm sure. Did a bit of assembler once on a BBC
computer...hated it! 400 lines of code to make an LED blink!
Scott
