I am in the process of installing a MJ & EDIS-8 in my Big Block Chevy.
I have a MSD RPM switch left over which I could use to cut off the electric fuel pump at the rev limit.
Anyone see any disadvantages using the regular MJ Soft Rev limit together (100 RPM before rev limit) with a fuel pump cutoff at the rev limit? Anyone done something smilar?
Or could I even use the inverted output feature of the MJ to deactivate a fuel pump relay at a certain RPM?
Soft Rev Limit & Fuel Cut Off?
1971 Monte Carlo, 454 HO, Tremec 5 Spd, Weiand 177 Supercharger
Thanks Brent,brentp wrote:Assuming you're running a carb'd setup, disabling the fuel pump might be a bad option as the cut would not work instantaneously as fuel remains in the carbureator bowl for some time- likely long enough to power the engine through an over-rev condition.
I should have mentioned that this is for a Throttle Body Injection system, no carb...
Thanks!brentp wrote:Ah, got it.
Still, you'd have residual fuel pressure in the lines, which might power the engine into a danger zone.
is the fuel injection system capable of doing a fuel cut at the injector?
You could still do an ignition cut. The plus side is you might get some pretty exhaust flames
In that context, short of upgrading to the hard rev limiter, what would happen if one were to use the user output of the MJ to ground the + VR sensor signal to the EDIS at upper rev limit?
Interfering with the VR sensor signal is an interesting idea and might work to act as a rev limit. It might cause plug mis-firing when interrupted at any random time (e.g. interrupted when the coils were dwelling). Plus there might be a delay in re-acquiring the signal.
However, the user outputs of the Megajolt have a +12V pullup when in the "off" state, so it would interfere with the VR sensor signal regardless of the state.
Spockie-Tech
bobclevenger
- Contact:
Just thinking out loud here, but why not connect a relay to the coil output wire of the MJLJ (along with the coils, of course) and use this relay to run your fuel pump? You'd have fuel being pumped whenever the coils are powered up, but not when they are shut off (either normally or due to over-rev condition).
...Bob
I did not know that there is a coil output on the MJLJ without the hard rev limiter installed... Is there?bobclevenger wrote:Just thinking out loud here, but why not connect a relay to the coil output wire of the MJLJ (along with the coils, of course) and use this relay to run your fuel pump? You'd have fuel being pumped whenever the coils are powered up, but not when they are shut off (either normally or due to over-rev condition).
bobclevenger
- Contact:
My error. I was thinking of the hard rev limiter.FULMNTE wrote:I did not know that there is a coil output on the MJLJ without the hard rev limiter installed... Is there?bobclevenger wrote:Just thinking out loud here, but why not connect a relay to the coil output wire of the MJLJ (along with the coils, of course) and use this relay to run your fuel pump? You'd have fuel being pumped whenever the coils are powered up, but not when they are shut off (either normally or due to over-rev condition).
...Bob
