I hook everything up as in the installation pics.Using the minimal required diagram.I have power and ground where I needed it.The ckp sensor is hooked up right.I tried it both ways to make sure.I scoped the ckp sensor and the inputs to the coil.I have good waveform from ckp.No waveform to either pin 1 or 3 at coil.pin 2 at coil has 12v.I dont have tps or map hooked up to the mj.This should not cause it not to have spark?
Just to make sure it was not the coil.I replaced.Still no spark?Mj has power.The green light is on with ign on.I have not plugged into the mj with my laptop yet.
Is saw 5v ref?And pip is 12v ref?Tring to figure out how to test the mj besides power and grounds?
I have looked over the full pinout diagram for the mj.But it should produce spark with just the minimal wires hook up right?(12v,ground,pip,saw)..Ready to pull my hair out..Any help would be great..
