can I use a MAP sensor??
mrknighty
Post by mrknighty »
Hi all
I've been look into mjl system and I'm sure it will improve performance/drivabley on my car.
I have got a peugeot 205 Gti on twin 45's carbs with a Piper 300 degree cam shaft, would it be ok to use the MAP sensor with this setup?
any help would be greatfully recived
John (UK)
Todd Charles
You could use the sensor but
Post by Todd Charles »
You could use the sensor but you will need to hook a vacume gauge up and see what you are running at idle and cruise. You may be better off with just a "mechanical advance" setting. You would still see improvement over stock.
Todd
