3 cylinder using EDIS-6 possbile?
sonicman
Post by sonicman »
I have a Suzuki Mighty Boy, it has a suzuki F8B (800cc, 3 cylinder) engine installed.
Would it be possible to use an EDIS-6 system, but only using half of the leads (the half that corresponds to a 3 cylinder pattern, eg 120', 240', 360')?
Is it even feasible? What problems can I expect?
Definitely investigate the firing order of your engine, and if it matches 1/2 of a 6-cylinder application, I'd say go for testing it out! You might get away with using coil-on-plug units instead of the standard coil packs, if the 'missing' cylinders map (firing-order wise) to the 6 cylinder configuration.
If this is the case, try using the units from a 2000 Ford Escape; others might work as well.
Keep us posted on what you find out!
sonicman
Post by sonicman »
The firing order is 1-3-2, 120' crankshaft angle, so compression every 240'.
So you think I should use COP and fire it every 120' so that I don't need a camshaft sensor?
sonicman
Post by sonicman »
Also, if i was to use a 6 cylinder wasted spark coil, would i tie the spare coil posts to ground or leave them open?
