2 stroke twin
tonyb
2 stroke twin
Post by tonyb »
i'm looking to use megajolt with a Rotax 500cc parallel twin snowmobile engine firing every 180 degrees, is it possible? if so what bits would i need other than the megajolt and trigger wheel
cheers
tony
Hi Tony,
search the fourm for 2-stroke - it should be possible in theory since the wasted spark fires twice as often as needed in a 4 cylinder application.
