Reply to topic Page 1 of 1
connecting problems again
Post connecting problems again
so after sending my ecu back to get repaired i have the problem again Sad
last time it was the processor + oscillator, i received it back and everything was fine so i left it at that
finally got the car on the road today plugged it into my laptop which is known as working using the rs232 port and getting the timeout error like i did last time
the led is lighting up on the ecu but still no connectivity just the same old timeoutt error
ive ran the car with and without the ecu and there is no difference so im taking it as its not advancing
anyway i can check to see if those have failed again before i send it off again Sad
ive followed the testing voltages part on here and everything is fine
Post
Verify +5v at the test point. if the test point is covered with green solder mask, you can test on the adjacent pads on D1 or R9.
im getting 4.94v
U1: Verify +5v across the Vdd, Vss pins of U1
4.94v
IC1: Verify approximately +V-Supply (about .6 volts lower than +V-Supply) across the IC1 CD+ and Gnd pins
7.09v
U2: Verify +5v across Vcc and GND pins of U2
4.94v
QG1: Verify +5v across Vcc and GND of oscillator QG1
4.94v
those are the readings im getting from the various pins
Post
Post
Hi, sorry youre having problems again. I replied to your private message but please reply here with your findings.
Post
As Im currently in the country i have pm'd swedge and hopefully i can be of service.
Wink
Hope i haven't been missed
_________________
View user's profile Send private message Send e-mail MSN Messenger
Post
Hi guys sorry for all the pm's but I have a 240 mile trip with my car club on the 18th which I might have to miss now
nothing different has happened to the car it's sat in my drive and been started a few times since I received it back from you
I finished fitting the interior so took it out on the road and didn't feel right so I hooked it up to my laptop through the rs232 port and no connectivity again
I've drove it with and without the ecu and there's no difference I've hooked it up to my main pc using the rs232 port and still nothing
Gonna have a check over of my alternator and make sure it's not over charging or anything
I'll get the ecu posted out today nitropixie I'll send my cables too just in case it's them
Thanks again Smile
Post
Wink
_________________
Post
Thanks Ryan- yes we missed you!
We will get it sorted out as soon as we can.
_________________
Founder, Autosport Labs
Post
hi guys just to let you know, ive tested my alternator and im getting 14.4volts on idle
give it a good rev and it goes to 14.7 volts no higher
when i put the heaters on heated window blowers etc it drops to 12v
give it a rev and it goes to 13v
so the alternator is working fine
