MJL - wiring of plug.
Spitty
Post by Spitty »
Hi, i have the MJL c/w Internal MAP and just need to know which way round the wiring is shown for the unit in the installation guides; is the picture shown looking into the plug from the MJL side or, is it looking into the plug from the wiring side?
Also, what size is the spigot for the vac connection please?
Cheers, :?
Hello Spitty,
In the installation guide the molex plug orientation is looking into the Megajolt unit. It should be depicted in the diagram as well.
For the vacuum line you want the smallest thin-walled tube you can find - 0.125 " inside diameter.
Spitty
Post by Spitty »
Many thanks for the quick reply.
So if i'm right that means, power (+ve) goes to the bottom right and (-ve) goes to the top right as i look at the unit.
Which also means that positive and negative are bottom right and top right respectfully looking into the backside of the plug.
Thanks again. :D
That's correct sir!
Spitty
Post by Spitty »
Many thanks Brent, is much appreciated. :D
