Ive just installed my MJ on my Toyota 4AGE 16v engine all started and installed with no problems which was great engine idles perfect and revs freely.
However I have a problem under acceleration/load around 3500 / 4500rpm which I can replicate when stationary with no load.
Looking on the forum I suspect this could be the VR sensor installation but my bracket (pictures below) is quite heavy duty construction when compared to others 4mm steel with additional securing bracket.
A couple of questions:
My sensor is at a slight angle (follows the angle of the block) not 90 to the trigger wheel can this cause an issue? Ive seen another 4AGE installation were the sensor is at a similar angle.
The centre of the VR sensor or the eye part is not quite central over the teeth again is this critical I havnt found any information to say that it has to be dead centred?
Im thinking of borrowing an oscilloscope to see if the signal goes dirty when the problem occurs but my take me a few days to get hold of it.
Is there anything else Im over looking??
