TPS To MAP convertion on Mj E
Hans
Post by Hans »
Hello there, Iwant to convert Magajolt E from TPS to MAP
Ist there annything I have to do other than soldering in the MPX4250AP Sensor?
Hope someone can help, Hans.
cng1
Post by cng1 »
You can simply use an external MAP sensor and wire it up in the same way that you would a TPS.
www.trigger-wheels.com
Hans
Post by Hans »
Thanks CNG1,
so thats one way to do it, but having allready purschased the MPX 4250AP and prefering the neat solution of having averything inbuilt in the MJ E housing I would like to go down that road.
So again, is there more to converting from TPS to MAP than just soldering in the MPX4250AP sensor on the Megajolt /E ?
Hans.
Check the Megajolt/E board - If you have the black Rev E board, you'd just need to solder in the MAP sensor and disconnect the TPS. If you have the Green Rev D board, you will need to add 2 0.1uf 1206 ceramic capacitors to the pads C8 and C9 and 1 270 ohm 1206 resistor to pads R4, in addition to the MAP sensor.
Hans
Post by Hans »
Crystle clear exact information, thats what I like about this place.
Thanks Brent :D
Hans.
