.. Positive earth ... and a dynamo...
Gassed'58
Post by Gassed'58 »
Hi all, can anyone tell me if the Megajolt is suitable for a Positive Earth vehicle ?
I currently have it fitted to a negative earth vehicle which I am selling and wish to swap it over onto a positive earth vehicle.
This new vehicle will have a dynamo, I'm not sure the voltage control will be as closely contained as with an alternator so what voltages ( max ) will the Megajolt system cope with ?
Regards, Geoff.
Hello - It should work, given a few checks things:
- Ensure the EDIS mounting bracket is not connected to ground. I am not sure if it is. A simple continuity test will tell you for sure.
- The case of the megajolt is not connected to ground, so you are OK here.
- The frames of the coil packs are isolated as well.
Let us know how it works out!
Gassed'58
Post by Gassed'58 »
Hi Brent, thank you for the information it gives me the cheer to go ahead and get it done. I will certainly get back to you and let you all know how I got on. I think this will be a few months as things move slow here and I have to get the trigger wheel mounting worked out as the crank pulley has a combined vibration damper which makes it awkward. The engine by the way is an IOE Rover 1955 2 litre sometimes called an " F Head ".
Geoff.
