Current Ignition Configuration in MJLJ Config is Incorrect?
jestes
Post by jestes »
Based on the protocol spec, bit 7 of byte 6 in command 0x53 indicates the current ignition configuration. Set = Config 1 Cleared = Config 2. The MJLJ Configurator appears to display it backwards in the status bar.
