Run Time Display will not display!
Alex H
Post by Alex H »
I have connected up my PC to my MJlite and managed to load an ignition map, which appears to work when the engine is run. The map automatically displays when the PC is reconnected. My problem is that when I click on the "runtime display" on the tools menu no run time display appears-the ignition table remains.
I would be exceptionally grateful if someone could tell me what appears to be wrong. I have reinstalled the tuning software and Java several times but it hasnt made any difference. The last time I used the 13MB download from PioneerX which seemed to instal the necessary software and files correctly.
I have a TPS mod so really need to get the run time display working in order that I can pick up the output readings from the TPS to create a suitable map.
I hope that someone can help!!-thanks
