I've installed the MJLJ and so i can replicate my 'standard' ignition setup as a good start point i've measured the advance at static then for every 500 rpm increment thereon by increasing the engine speed whilst in the garage ie presumably no load(?).
I've then put these values into an ignition map and saved it ready to flash to the MJ.
Now, do these values represent hi or low vacuum ie do they go in the load bins '20' or '230' for example?
I'm guessing the '230' as it's off load and therefore hi vacuum?
