What type of spark plugs to use?
msinisal
Post by msinisal »
I know the heat range rating to use but do the plugs need to be resistor type? I will be using custom set of Magnecor Electrosports80 ignition leads, which are advertised to provide "exceptional RFI and EMI suppression" :-)
With dizzy setup I'd be using NGK BPR6EY.
viatron
would be interested if you ge
Post by viatron »
would be interested if you get a reply as i am looking for the same info.
Mac
itguy
Spark Plugs
Post by itguy »
I had real problems when trying to use NON resistor type plugs (NGK BP7ES's) and my ford xflow.
I swapped them for BPR7ES's (same but resistor type) and all was well again.
Will.
