Reply to topic Page 1 of 1
Vauxhall C20XE with TPS & Carbs
Post Vauxhall C20XE with TPS & Carbs
Engine Mfg: Vauxhall
Engine Code: C20XE
Cylinders: 4
Displacement (cc): 2000cc
Rev Limit: 7,000 (standard is 6,800)
TPS or MAP: TPS
Boosted or Normally Aspirated: Normally Aspirated
If Boosted- max Pressure (KPa): N/A
Modifications: Twin Weber 45 DCOE
Chassis: Westfield SEiW
Notes: Set up by Pro-Tec Motorsport on their rolling road, using Fodderboy's base map as a starting point. RR operator commented on "big gaps" in the base map? This dyno print out used the stock MJLJ map last year. After remapping and proper TPS setup the car ran +10bhp.
Vaux C20XE TPS map from Pro-tec.mjlj
 Description:
Download
 Filename:  Vaux C20XE TPS map from Pro-tec.mjlj
 Filesize:  816 Bytes
 Downloaded:  897 Time(s)
