Noteworthy feature in this release - live monitoring of sensor channels. This is an interim release before 1.2.x since this feature is so needed.
Enjoy: http://www.autosportlabs.net/RaceCapturePro_Downloads
Now off to preparing source code repositories for public release!
Race Analyzer 1.1.10 released
Live Monitoring Crashes Application
Is anyone else experiencing issues when trying to use the live monitoring feature? I can get it to run once in about 20 tries or so but not consistently. I've tried reading the configuration first, unplugging the hardware before starting monitoring, unhooking the sensor before starting monitoring, but nothing seems to work!
When it doesn't work for me I get the following message:
"raceAnalyzer.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
Error Details:
AppName: raceanalyzer.exe AppVer: 0.0.0.0 ModName: libstdc++-6.dll
ModVer: 0.0.0.0 Offset: 00025c3c
Attached is the text file with all the details.
Error Details:
- 66bd_appcompat.txt
- (4.31 KiB) Downloaded 534 times
Yes, it runs fine and works normally until I try to monitor signals. I thought it might be my administration rights on this PC but when I switched to the full admin account, it worked for a while and then started crashing. It seems to default to COM port 2 as well and I have to manually switch it back to the correct port (not sure if that helps).
Thanks for the speedy response and don't hesitate to ask if you require additional information!
We have what is hopefully a fix for the live monitoring feature. You can find version 1.1.11 here:
http://www.autosportlabs.net/RaceCaptur ... _Downloads
Let us know if it resolves your issues!
