Importing CSV file from Racechrono
Slider
Post by Slider »
Is this possible? Everytime I try to import the csv files it says "No channels detected! Did you select a valid log file?"
Mike
First thing you should do is load up one of the sample RaceCapture/pro log files and compare the format and search for differences.
You can also post your CSV file here (or link to it) so we or others can take a peek at it.
Slider
Post by Slider »
Thanks for the quick reply, it wouldn't let me upload here since it's above the file limit (724kb) so I uploaded it to sendspace http://www.sendspace.com/file/ctpnss
If you could take a look at it that would be great, hopefully there's a fairly simple way to make it work. I'm not sure where to start.
Thanks again!
I took a peek; you will need to delete the extra data at the top of the file before the headers at the very least.
