My name is John and I am in Coatbridge Scotland.
I purchased a Megajolt JN Kit last year from Trigger Wheels uk.
I have just got around to fitting it to my 1971 TR6 2.5, PI, 150 BHP, the reason for this was I was having the car painted.
I have now fitted the Megajolt jn to the car, and it is not running very good.
Its as if it was running on 2 star petrol, or the timing was to far advanced, its pinking when i push the throttle.
And when I took it out for its first run it was pinking like mad and lacked power, I was lucky to get to 3rd gear.
So I got it back to the garage, and I thought it was dodgy fuel.
I had put 30 litres of Super Unleaded Ron 97 in it,
so I drained the fuel and replaced it with 30 lts of Unleaded Ron 95, and fitted a new set of plugs.
It is still pinking but not as bad as before, it still lacks power.
So I decided to check my instulation work of the Megajolt jn system and the trigger wheel 36 - 1.
Everything has checked out fine.
So I am kinda stuck as to what to look at next.
The MAP is from Trigger Wheels and it came with the system, its the Triumph GT6 map.
When I had the laptop on the car it was showing 12 in the ignition advance , should this not be 10.
and if so how do I change this value.
Scooby5654
