Thanks for the update!
I wish we had those here in the states. That has to be one of the nicest black paint finishes I've seen!
Ford Escort RS Turbo up and running uk
flashrs1988
Hi all, just thought I’d add my success to the list. I now have my Ford Escort 1600 RS turbo up and running with MJ LT, all seems to work very well and I am now getting to grips with the finer points of mapping. With only one days setting up, the car is much more responsive to drive, than it ever was with the Bosch ignition ecu that is fitted as stranded.
The other good point with MJLT is that there is no pre set boot limit. Which can be a right pain with the stranded ecu. The only option for the old ecu would have been to have I (chipped), which would have cost more than it cost to build and install MJLT.
Check out the link for a couple of picks
<a href="http://homepage.ntlworld.com/clark.rs/jult_1.htm "> MY photos of instal </a>
<img src="http://homepage.ntlworld.com/clark.rs/p ... rs1988.jpg" />
<a href="http://picasso.org/mjlj/?q=filestore2/browse/F" ?> current map config </a>
Cheers
Steve
Cheers
Steve
