part numbers, connectors, modules, sensors, pigtails
bsimon
Post by bsimon »
Although it's probably been covered in several earlier posts, I thought it would be nice to have a one stop shop for EDIS part number references. These are all Standard Motor Products part numbers. Most auto parts outlets can cross them over to their store brand.
CONNECTORS
S-744 edis module pigtail
S-755 coil pigtail
S-812 crank and cam sensor pigtail
S-674 tps pigtail
SENSORS
PC19 VR sensor angled forward
PC51 VR sensor angled down
PC74 VR sensor straight
PC27 VR sensor cam type
TH169 throttle position sensor
MODULES
LX239 EDIS-4 module
FD-487 coil pack
You can go to www.smpcorp.com and enter the part numbers to look at the parts. This is particularly helpfull when picking a VR sensor.
Todd Charles
Good stuff especially on the
Post by Todd Charles »
Good stuff especially on the pigtails. Many yards will not let you cut up good wiring harnesses. Thanks,
Todd
bsimon
Post by bsimon »
Update on part numbers.
I can't find an equivalent for the EDIS-4 or EDIS-6 module pigtail. It seems only the S-744 EDIS-8 pigtail is avaiable. You can still use the S-744 of 4 and 6 cylinder modules but you'll have to cut some of the connector's keying features away to use it.
