getting .5 volts from user output(#1) is that all it puts out?
Digital output?
Looking to get a12 volt switching at 4k rpm to a relay
I have user output 1 inverted and set to 4k so it should be on till 4k and switch off over the set rpm.
Software indicates operation but .5 volts?
Attempting to operate Toyota Variable Induction with v4 MJ via low draw relay.
User Outputs?????
