Not writing logs or sending telemetry data
All the lights seems to flash correctly. I have it set for CSV file. T-Mobile SIM installed and lights seem to flash happily.
Ideas? When I log in on-line there is no session to look at as the instructions say there should be.
The email account is [email protected]
I'll have to get a team mate to download the setup but it looks just like the wiki but with our device ID typed in.
Ok, I checked the website and your device hasn't connected or sent any data. Can you tell me what speed the middle LED blinks at? Different speeds mean different things:
http://www.autosportlabs.net/RaceCaptur ... metry_LEDs
Ryan Doherty
Autosports Labs
Autosports Labs
Hi Ray,
It would be good to check your RaceCapture/Pro config file. we want to make sure you're not setting a logging rate that's too high - it would overwhelm the connection.
Also, are you powered via USB only or hard wired to the car? When transmitting via telemetry, USB alone does not provide enough power.
Config file. The board would not accept the rcap file type so I changed it to txt. Hope it works.
Is there a way to email you the file directly?
- nosm_default.txt
- (7.9 KiB) Downloaded 1070 times
Hi Ray,
did you enter the Telemetry Device ID that is generated when you register your Realtime device on www.race-capture.com? If I'm reading it correctly, it's blank in your configuration:
"outputConfig" : {
"sdLoggingMode" : 1,
"telemetryMode" : 0,
"telemetryServer" : "54.245.229.2",
"telemetryDeviceId" : "",
"p2pDestAddrHigh" : 0,
"p2pDestAddrLow" : 65535
"outputConfig" : {
