Random channels missing from Sensor Monitor?
GTIspirit
Post by GTIspirit »
The RaceAnalyzer Sensor Monitoring was a really cool feature, but operation appears rather erratic. When I open it I am usually missing a channe. Once it was once of my Accel channels. Now it's the GPS Speed channel.
If I open a second instance of the Sensor Monitor, I now have Speed, but AccelX is missing.
I'm also missing a pulse input I named "Wheel" because it gets a wheel speed signal from the speedometer.
Since there is no user interface to select which channels you want to view, I assume it should show all channels which are Enabled. Or in SW speak, it probably shows all which are !Disabled.
gizmodo
Post by gizmodo »
Try resizing the monitoring window. This has worked for me in the past.
We've released an updated version of RaceAnalyzer (1.1.14) and firmware (1.2.6) that helps with the sensor monitor. The firmware was periodically omitting channels from the samples, and we hopefully fixed crashing issues with the sensor monitor on some windows platforms.
