I have a weird problem..
Everything worked perfectly fine at first, but now the TPS-gauge in the Megajolt Software takes steps of 9%. Normally you can see 0%, 1% etc all the way up to 100%.
I tried to refresh the firmware, re-calibrate the sensor, none of which worked.
I can't see a bad connection to the sensor as well so I don't know were to look and am out of guesses.
Anyone?
PS: I think the ignition timing is still working fine, because it still interpolates between 0-9-18-27 etc %. The software just isn't displaying the correct percentage.
TPS takes 9% steps
