I'm getting ready to install the megajolt system in my bug and I'm adding a Innovate Motorsports LM-2 Air/Fuel Ratio gauge/data logger to the mix as well. I purchased the tach adapter from Autosport labs, will it be ok to connect both my data logger and my VDO tachometer to the signal output from the tach adapter?
Multiple Tach Signal outputs
bladerunner80
It will probably work but I'd recommend keeping things separated if possible. Why not feed the Innovate from the Megajolt or EDIS tach output?
www.trigger-wheels.com
bladerunner80
Thanks for the reply. I just assumed it would be easier to wire the tach via the optional tach output board, from reading, it seems there are a lot of people who have trouble getting a proper signal via the EDIS/Megajolt, but maybe I'm understanding it correctly. I'll take your suggestion and do it that way, then if I run into problems, I'll use the tach output board I bought.
