I plan to use the megajolt with a carb setup (on a 4age) with a steering wheel switch activated nitrous setup.......
My Question is........ can I use the said steering wheel activation switch 'as' the Option switch ? To retard the ign map whilst on the gas ? Is the switching instant?
And if that will work how can I make the map switch back when I'm not on the gas ???
Hope that makes sense......
Regards Mark
