TPS to MAP sensor???
fiestatony
Post by fiestatony »
hi there guys and gals, I'm tony and just signed on forum :-). Hi.
Anyway..... I have been running tps previously and now need to run a map sensor
.. now then can I run an external Map sensor and wire it to the TPS wires that
are there already, or do I have to change internals of mj as mine does not have a hole
for vacuum take off...... PLEAS HELP ME
Thanks a lot in advance.
Tony :-)
Hi Tony,
Apologies for the late reply. You can switch from TPS to an internal map sensor by soldering in a new sensor and modifying the end plate with a hole. Could you post a picture of the main board inside your Megajolt and we can advise you on how to do it?
