Just a quick question about the +5V reference output from the RCP unit. Is that safe to drive multiple analog sensors (maybe 4 sensors) from that single 5V lead?
Thanks.
5V reference
From the schematic on Github, the VRef output is internally protected by a 50mA PTC (self-resetting fuse) so as long as you don't go over 50mA total, you can drive whatever you want. Current is figured by volts/ohms, so at 5V out, if you've got a 1k throttle position sensor, that's 5mA = 0.005A. You could run 10 of those and be right at the limit. If your sensor is a 10k load, that'd only be 0.5mA, and you could run 100 of them.
So the answer is, it depends on your sensors.
momostallion
