No tach on tablet
turbo329is
No tach on tablet
I was able to read the tach value on the laptop and I enabled logging at a few different frequencies, but i get no tach displayed on the tablet. I'm using a samsung galaxy tab 3 8" and it's my only display except for a shift light with a tach readout. All my other sensors are displaying, but may be jumping around a bit more than they should. I would have guessed that the problem was caused by sharing the ecu signal with both the shift light and the racecapture, but since I was able to read it on the laptop I suspect the problem is with the connection to the tablet or with the android app. I should have verified that I'm logging tach values before posting this but I forgot the sd card in the racecar which is now 200 miles away.
turbo329is
