MAP NEEDED 1380cc mini rally car
Warning634
Post by Warning634 »
Engine Mfg: A-series A+
Engine Code:
Cylinders: 4
Displacement (cc): 1380
Rev Limit: 7500
TPS or MAP: MAP
Boosted or Normally Aspirated: NA
If Boosted- max Pressure (KPa):
Modifications: Cyliner head MED offset race 38/31, titan roller rockers, Omega Pistons 70cc, MED AGSP camshaft(FULL RACE), Cooper S 521 lightened, balanced, polished rods, 1275GT 1505 Ni Temp, cross drilled, bladed wedged crank shaft, ultra light flywheel & back plate, richard longman built split 45 DCOE's
Chassis:
Notes: Compression test of each cylinder 210psi, when it was on the rolling road at Richard Longmans the ignition timing was 20* at idle and 30* total and that was with an aldon 100 ARP
really need a new map for this set up....please can someone help mega urgent as i have an event in under 2 weeks..
thanks
kevin
toenee
Post by toenee »
I started with the 'MiniSPi2-MD286.mjlj' (it's quite a soft map) and went from there, adjusting it to suit your engine. Ideally with a wideband AFR gauge connected.
